crazy clearance issues
    I did an automatic 5spd. conversion on a 92 accord dx. i swapped the rear mount and used a transmission, mount, and bracket from a 90 Accord EX 5spd.i left the same F22A1 .The transmission and mount couldn't fit.the transmission bolted on but the bracket and mount wouldn't line up. it was impossible to bolt up all four mounts. we switched up the order in which we bolted up the mounts but it didnt matter we read some where that the front mount needed to be changed but that made no diffrence either. finally i put a 97 transmission,mount,&bracket. it fit but on the timing belt side i have no room to take off any of my belts. the crank pulley is less than an 1/8 of an inch away from the chasis. its very tight. to take off any belts i have to unbolt the left and right mounts and pry the engine over . its too much work to do simple maintainance its so tight on that side of the engine bay.
    ANYONE HAS A CLUE WHY?????????
    so you put in a 97 tranny with a 97 tranny mount & bracket?
    if so you will always have that problem till you get the custom tranny mount. cause from what Ive heard the CD5 & lude mounts push the engine/tranny 1/8s foward & 1/8 to the drivers side.
    also I think your suppost to stick some washers under the drivers side mount, but dont qoute me on that.
    hope that helps
    93 Accord LX Sedan (sold)
      which custom mounts have an idea where i could get it from car, dealer, junkyard, special website.??? pplease let me know that info is very helpfull
        did you tap the transmission to use the accord mount?
        Please, Leave me some feeedback on my ride ^CLICK ^CLICK ^CLICK
        But Honda guys know EVERYTHING about EVERYTHING! If you don't believe that, then you're just wrong...
          hmm.. never knew that about CDs/BBs.
          hope that helps
          Originally posted by toycar
          Braking the bank, maybe. Feeling like a boss, likely.
            no, just used the same year(97) mount bracket and tranny it bolted right up no taqpping was necessary
