I was taking a look at the differences between the f22 in my accord and the f22 from a prelude s that i bought to put in and noticed that the lude motor has a coil mounted behind the cap to the dist. with a wire to the cap. my accord doesnt have that wire at all. what should i do to make it work? i was planning on using the harness off the motor in my car. will it work like it is or do i need to change something?
Prelude S f22a1 into My CB7 ?
your f22 has a internal coil. as where the f22 in the prelude has an external. some people change from the internal coil to the external. the 90-91 i think came with the internal and the 92-93 came with a external. anyone correct me if im wrong it will work no problem
heres a couple diys about it
CLICK ME!!!bought from - b-bomb, Davids92Accord
sold to - Old School, DA92CB7, F22Cb7Rid3r
^^ R.I.P. you will be missed
Originally posted by green97cb7your f22 has a internal coil. as where the f22 in the prelude has an external. some people change from the internal coil to the external coil. the 90-91 i think came with the internal and the 92-93 came with a external. anyone correct me if im wrong
Originally posted by bigredtopsrso the external is better? will my wiring harness need to be modified?bought from - b-bomb, Davids92Accord
Originally posted by Cb7GHOSTonly possible advantage is that you can use MSD ignition on external coilTake that freek show to the park, maybe the squirrels will care.
Originally posted by Old SchoolElectrical circuits are affected by heat. As temperature is raised so is resistance. An external coil will generally be cooler. This will help reliability and performance of the coil.
Originally posted by mj213Just curious, wouldn't this be kind of a waste, to swap the entire engine just for a little less heat on the coil?
Maybe I'm just lazy :P
If you used the harness off of the prelude engine, you won't have to do any rewiring, and then it won't matter if it has an external coil.
Also, the only way you will really get any more performance out of that motor (not what you are looking for, I know) is if you have the P12 ECU. Mine (I have a prelude S, but now a H22 swap) always felt more snappier than my Accord.1992 Prelude S w/swapped H22A
The ECU is the only significant difference between the two motors. That is where the 10hp difference lies.
If you're doing it for reliability, then that's fine. The motor is the same as yours. Just get the ECU for the extra 10hp. Otherwise, it's an identical swap.
Use your internal coil dizzy to make things easier.
For the internal/external distributor... just about everything said above is correct. Unless you have the mods to justify an upgraded ignition system, there's no need to do anything to it. The internal coils don't usually heat up enough to do any damage when all is stock anyway. You can convert to external coil of you want... you don't need to change anything. You just need to add some wires. I believe there is a DIY on this forum somewhere. I'm still internal on my H22, and I never bothered converting. I did burn out one coil so far though... a junkyard replacement works fine.
