EGR Cleaning, need advice
    So tomorrow, im going to be removing the EGR to see how bad its gummed up, when im getting 400 km per tank, its really hurtin the wallet. Does anyone have some advice on how to clean this? I know to get it off, its 2 12MM bolts (or 14), and a new gasket is required. But im curious on methods of cleaning it out.
    Thanks muchly
    90 Accord EX F22a1 Auto R.I.P.
    2011 Mazda 3 Hatch 2.5L GS sport HELLO!
    Throttle body cleaner or brake cleaner.
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      throttle body cleaner works great. although it doesnt get it all off. you might need something a lil abrasive to pull the gunk out of the inside. i know i did. seafoam actually makes a TB cleaner called deepcreep. i think ive seen it at pepboys
      no
      Accord turbo kit under $2k here
      $30 HID kits here Thread
      "What a selfish bitch. She looks like one too. A smart-mouthed, facebook-ing, "i dont know if im straight, bi or *** yet" little brat." -greencb7inkc
      "No Herra Frush, Slammed, tucked or frame dragging here. I'll leave that to the mini trucks...." -fishdonotbounce
        ive used deep creep, it works well but i didnt h ave the patience to let it sit since i was doing it at work.
          brake cleaner is what me and my friend used on his EGR on his ford ranger. his intake manifold and EGR were so bad i'm surprised he was able to drive it as long as he did. it was almost solid.
            More or less im looking for ways to get the valve open, so i clean inside the EGR as well, also what can i use to clean past the ports on the intake manifold?
              Brake clean or TB cleaner. Not sure on your car but the gasket may rip when you remove it from the intake manifold.
              200SX SE-R w/ turbo lowport & S4 cams
              Versa SL 6 speed
                I cleaned out my EGR ports last week and I was sent to these links:
                http://www.preludepower.com/forums/s...d.php?t=275440
                AND
                http://www.cb7tuner.com/vbb/showthre...hlight=seafoam
                these helped out alot so good luck man, it wasnt that hard to do either.
                My CB For Sale
                  hook up a vacuum pump to the line and pressurize. it should open and you're all set.
                    Perfect man, THanks a ton! Im not going to be opening the ports to the manifold, to me thats just riskybuisness since honda is not open today, and i cant get there for a while. So im just going to clean the Valve, and remove what i can from the intake manifold, and let everything go through the motor. im going to try and get a wire brush in there without damaging anything.
                      I would just stay with the TB cleaner. Brake cleaner is a bit harsh on rubber and it can make your EGR diaphram brittle then crack eventually...
                      Sig removed due to excessive size
