ecu
    ecu
    I know that for a lot of other cars it's easy to get chipped ecus done, but is there anything available for the f22a, other than a stand alone? I know that tuning would be car specific but i was wondering if there was like a "stock enhanced" sort of thing that i could have done at some point.
    Cars:
    91 Accord LX Sedan (sold)
    98 Accord LX Sedan
    95 Eagle Talon TSI AWD (E3 16G, PTE 780cc, Godspeed FMIC)
    Most people have found that for a standard I/H/E setup the PT3 or PT6 (stock ECUs) work fine. Only when you get into aggressive changes, like porting, valve jobs, different pistons, etc will you really notice any difference.
    You might look at getting a P12 out of a 92-96 Prelude S if you have a F22A1 or A4 motor. It might give you a slight upgrade. Do a search and you will find out more if you are interested.
    1992 Prelude S w/swapped H22A
      yeah i have a f22a1, ill have to check that out.
      Cars:
      98 Accord LX Sedan
        Civic ECUs are used for tuning purposes. A P06 from a 92-95 Civic LX/DX would be able to be modified to run an F22A. You would need to do a custom tune, however.
        Look in the ECU Tuning subforum of the Technical section. Lots of info there.
