Hey guys! Ive been working on Hondas for about 6 years and have NEVER been this stumped!
The car: 91 lx sedan m/t
Problem:
Cylinder no. 1 is dead. You can pull the injector plug off while its running and it doesnt even throw a code(all other three cause CEL) . This is definitely a fuel issue as i HAVE verified spark.
Attempts to fix:
-compression check (good)
-new distributor
-new plugs
-new wires
-new fuel pump
-known good ECU
-known good injector resistor pack
-known good injectors
-known good MAP
-clean fuel rail
Im past the end of my rope here! Any insight would be appreciated!
thanks!
Problem:
Attempts to fix:
-new distributor
-new plugs
-new wires
-new fuel pump
-known good ECU
-known good MAP
-clean fuel rail
thanks!
