the most obnoxious problem ever! (cyl 1 dead)
    Hey guys! Ive been working on Hondas for about 6 years and have NEVER been this stumped!
    The car: 91 lx sedan m/t
    Problem:
    Cylinder no. 1 is dead. You can pull the injector plug off while its running and it doesnt even throw a code(all other three cause CEL) . This is definitely a fuel issue as i HAVE verified spark.
    Attempts to fix:
    -compression check (good)
    -new distributor
    -new plugs
    -new wires
    -new fuel pump
    -known good ECU
    -known good injector resistor pack
    -known good injectors
    -known good MAP
    -clean fuel rail
    Im past the end of my rope here! Any insight would be appreciated!
    thanks!
    I had the same problem but it was with #3. Did the same things as you did, and still nothing. But I went ahead and did a swap :/
    Does your's idle like shit once the car has warmed up ? And get to the point where the idle drops so low that the car wants to die ?
    I would also like to know how to fix this problem :] So maybe I can salvage my F22 and save it just in case something happens to my H ...
      you said that the injector is getting a signal to function right? cause it doesn't sound right to not throw any sort of code if unplugged
        um i can see your point/ pain....
        1)- fuel filter good?
        2)- check the fpr?
        3)- clean where the injector goes into intake manifold..maybe dirty?
        4)- something is grounding out injector one.
        just throwing out some ideas
        x
          try another wiring harness
            x2
              Is the bottom of the head faulted? If it is it won't let it spark correctly... but then again... you just said it'd spark...
              hmmm....
              -Lance- (Formally known as H0ndaspyd3rLM)
              Originally posted by H22Artman
              if he still disagrees. well...... buy him a pink sweater and tell him to go buy some curtains.
              I posted a nude photo of myself on cd5tuner.com... it broke the site.
              Bought from: lo_dit, 924dr, Fatman88, 91project, noobcake, loud92cb7
              ٩(•̮̮̃•̃)۶
                Do you guys have a noid light? I would hook that up to the #1 cylinder and see if it pulses the LED in there. IF it does then the wiring is ok and the issue is probably the injector itself maybe. IF the light doesnt pulse it shows nothing is going through that wire so you might need a new wiring job on that section. You could do a harness but thats a bit more work. If you have a noid light I would give that a look see. The JTC ones are nice but pricey.
