I just noticed that when I go reverse on full steering (meaning all the way to the left or right) something is rubbing on the wheel well. On that position I stop and check for the rub , results that I didn't see anything that rubs. Tires don't rub the inner well. Any idea what that is?
Also , when I shift to reverse I hear a clunk noise in the transmission area. I can also hear this noise when I brake on reverse , sudden brakes and accelerate from sudden brake. I have check all brake hardware to see if they are all installed and tightened properly. Yes they are.
So far on the suspension I have done the upper control arms w/ balljoints , outer tie rod ends , wheel bearings , lower balljoints , new brake pads and new brake rotors. I get this clunk occasionally like when I first got the car it was there then months later it disappeared then suddenly came back again.
Any help would be appreciated.
