1 pcs jdm headlights?
    I found the thread on DIY blackhoused USDM headlights! Does thhe same proceedure apply to jdm when it comes to heating them up?
    DO NOT repeat DO NOT stick in the oven. Utilize a heat gun to open up.
    Trev.
    RETIRED...
      Trev.
      Heat gun....i hear a hair blower works...what else? pics?
      *Needs*
      -New shocks
      -Struts
      -Drop
      -Cleaning
      -New Tires/Wheels
      -New Window Tint
      -Alot more lovin'
        or solvent to dissolve the glue
        Click sig to view MR thread
        Links to other rides:
        Honda Accord Euro-R
        Honda Odyssey Absolute
        Honda City I-DSi
        Honda Stream
          Sorry for the initial response and being vague.
          Due to the lenses being plastic a heat source such as heat gun, hair dryer, or solvent, are you best choices. With these alternatives, you can actually monitor the lights much closer.
          Using the oven and on high heat, will cause discoloration/cloudiness to the lenses. And may not be able to obtain the clearness of the lenses.
          RETIRED...
            1 pcs jdm Headlights!
            Thanks for the help. I will try my heat gun
              I put mine in the oven, but it was low heat like 250 degrees.
              Gary A.K.A. Carter
              [sig killed by photobucket]
