R-12 to R-134
    R-12 to R-134
    how much does it cost to convert the a/c and what does it take to do it?
    you can run both in your car, just make sure most of it is R12 if not I think you would just need a new dryer and compressor so I would say under 450.
    Click Me
      convert the A/C
      clicky the siggy!!!
      ARCADIA GREEN MEMBER #20
      AIM=SleepygreenCB7
      Yahoo=annamaineeak@yahoo.com
        Whatever you do, DO NOT mix R12 and R134, bad shizzle happens.
        Have the current refrigerant vacuumed out by a shop (should be very cheap) and then buy a DIY conversion kit. It's easy to do, and you can buy them at any auto parts store or even Wal-Mart.
          few shops offer r12 recharge, at the dealership I was at we only did it if you didn't have leaks.
          The retro can involve just a vacuum and refill along with the addition of two new ports.
          In such a case you only will need...the ports, the vacuum and the r-134 refrig.
          However it usually involves a new line...I think the high press. line, but I'm not sure.
          In this case you add the above and also add a receiver drier. Your compressor should be fine.
          THe first one isn't as expensive...the second is an ass raping.
          ____
            Hey I am looking at doing this too... it seems that hondas from 90 on dont need new evaporators or compressors. We just need to evacuate the R-12 out and swap out the ports and put some ester oil in and then fill it with r-134a. I am going to do it this week so wish me luck too!
            AD5OS
            FOLDING@home
              I know some cars don't need the new lines...just the ports (which just pop on and you might could get at parts stores) and new refridge...but be prepared.
              I just realized with the new ports...you have to take the valves out of the old ports and then put the new ones on...so yeah...new drier.
              you might could get away with not getting a new drier, but a mechanic will tell you to install a new drier. You might could get away with it if you didn't have it open for long but it would be best to put on a new drier.
              Think about how long the system will be open while the ports are put on...and how long it takes to put in a new drier...seems to me the ports take less time...I would try without a new drier but the mech. doing it might not go for it...being an old part and all.
              ____
                why bother taking it to a mechanic? Just get the $30 kit and do it yourself.
                AD5OS
                FOLDING@home
                  You need it sucked out if you want it to last and run good.
                  wat?
                    If the car has no current charge, do it that way. Other wise, have it vacuumed out by a shop so you don't release all the refrigerant into the atmosphere.
                      why would a mechanic care about the ports or the drier if you just want them to evacuate the a/c?
                      Anyone here ever heard of someone using Propane to charge their AC?
                      AD5OS
                      FOLDING@home
