how to take off ignition rotor of 92 accord auto?
    yea i was driving my car norman everyday and runs good no problems at all.
    but one day i just got home wanted to park in the street and it turned off on me and it wont start on me at atll.i tried to turn it on it wanted to but died and not it doesnt turn on at all, i wanted to take off the main relay but i heard autozone checks if the ignition modules are good, soo i wanted to try the igniter first, but i cant take of rotor is there any screw in there or hot to take it off? any diagram that anybody has??????
    the fuel pump turns on i hear it,
    IT MAY BE AUTO BUT IT SURE RUNS FAST FOR A F22A6
    haynes says to pry it off with a small screwdriver. while pulling up on all sides.
    my h22 had a phil. screw in it.
    on mine stock one it had no screw and was stuck like hell so i dremel cut it off.
    FS: DSM turbo parts,OEM parts, and more.....
    My Members Ride Thread - R.i.P
      I can't remember for sure but if it does have a screw that holds on the rotor, you may need to turn the motor until you can see it. Just remember the car needs to be in neutral and to turn the crank pulley bolt(19mm or 3/4inch will work) counterclockwise(towards the front of the car).
