today i notice that my trunk was leaking water. i know its the black foam thats on the tail lights. does anyone know i can get a new set or what can i do to stop the leak?
trunk leak
are you positive it's the tail light gasket? there are other places the water can come from, such as the weather stripping around the trunk. that's where mine started to leak from again.
and i got my tail light gaskets direct from Honda. kinda expensive, but they're OEM, so i don't think it's too bad.Originally posted by deevergote.And please, for the love of God, type like a human being!
i've got a hole in the rear quarter panel also. i just used that RTV for sealing around the windshields and sprayed a HUGe glob into the area and let it roll down into place. i need to hit it up again for spots i missed.
that expanding foam will be like bare bondo, it'll absorb water like a sponge.
Originally posted by CB7 EXI'm sure its the tail lamp gasket cause i remove all the panels from the trunk i put the back seat down and got in there with a flash light while my girl strayed the trunk. it leaked bad. so i went to the honda dealer today and the wanted $28 a peice. crazy bastards
and if you don't want to get them from the dealer, hit up a local junk yard. just check to make sure the gasket is still soft, and not hard and cracked before you take it or it'll just leak like it is now. good luck with it!Originally posted by deevergote.And please, for the love of God, type like a human being!
