no fans when car engine is on, fans only turn on when off
    I've been running without a tstat since i bought my cb7 (po took it out not me) I installed a new oem one that i tested. it ran about 1/4 for awhile, then a few minutes laterit ran 3/4 the ways up no fans would tun on while the ignition is on, turn the car off with key in still in the ignition and i have some fan activity. turn the car on no fan. I jumped the wire leading from under the tstat housing and they both kicked on. I have concluded that a new temperature control is in order, what do you guys think?
    I'm not 100% but it could be your fan timer unit. Others more knowledgeable will chime in.
    "I'm a dude playing a dude, disguised as another dude"
    "That if thou shalt confess with thy mouth the Lord Jesus, and shalt believe in thine heart that God hath raised him from the dead, thou shalt be saved."
    Romans 10:9
    ><((((º>
      i had the same problem with 93 when i still had it's f22. it was the fan switch.
