Need info on Neptune Chipped ECU...
    Does anyone know anything about Neptune? I was searching for a chipped p28 ECU to get for my F20B Motor. And stumbled on Neptune. Can anyone tell me anything about it. What is the Neptune RTP used for?
    Any info at all?
      Dont know much about Neptune, but did you find your P28? Also did you know that you can also use a P06 and convert it to a P28. Just mentioning that because they are cheaper and easier to find
      SOLD!!
      Boosted H22
      375whp 298 ft/lbs at 15psi
        Yup I bought the P28 ECU already and will be getting it Thursday. I Got it for 80 dollars it was tested and working. But now I need to get it chipped so I can run my F20B motor correctly.
          Neptune is like Hondata or Crome. just a tuning program i guess. the difference between the RTP is just so you can tune while the car is on and running
          90 EX DUMPED!!!
            Thanks thats what I wanted to know. I'm going to buy it then hehehe.
              make sure your tuner can tune it before you buy it. You may want to make sure the Neptune software comes with it too.
                I new issue can one use a chipped P28 ECU for an Automatic? I talked to a local shop and they were not sure due to wiring? Has anyone ran a chipped P28 on an Automatic?
                  yes, you can run a chipped p28 on an automatic but not many programs can operate the automatic correctly. Do lots of research before purchasing. Make sure the program compensates for automatic transmissions. Whether its an auto ecu or not doesn't really matter.
                    Sweet!
                    I just got done talking to a Netune and Yes, if I get a civic/integra ECU I can use the NepTune RTP system to change the mappings to fit the car or I can visit a dealer and have them do it for me.
                      i heard neptune is the best i actually met the guy who developed it
                      member ride thread >>> http://www.cb7tuner.com/vbb/showthre...73#post3257973
                        Its all the same in my opinion. Its really all in the tuner if you ask me.
                        To the OP, if there isnt a tuner that works with neptune around your area, try Hondata. I think the s300 is very similar to the RTP. Like MRX mentioned, be sure to check and see if the program is compatible with automatics
                        90 EX DUMPED!!!
                          Hondata does not work on automatic.
                            can the neptune ecu be used in my stock f20b with triptronic tranny???
                            hmm,....
                            my '92 m'siaDM CB3 EXi
                            my '89 JDM CB3 EXi
                            my '98 JDM CF4 SiR
