replacing clutch master cylinder
    im going to replace my master cylinder but i'm not sure if i should do it on my own or go to a shop and have it done. i hav littl eexperience with cars so im afraid im going to mess it up. is there a diy on how to do this?
    alone in this game . ::My Ride My Way::
    Shouldn't be too hard...I think it's two bolts and taking off the line. All are 10mm...but don't quote me...cause might be 12mm. Sorry for the definitive answers
    You should rebuild it...costs half as much as a rebuilt one from the parts store
    Nothing to be scared of...get you a rebuild kit and it will just be a remove and replace as to the internals and remove and replace of the master cyl. itself. You will also need a haynes manual and I believe there is some sorta retainer clip in there also but I might be thinking of the brake master cylinder.
    Or you can buy a rebuilt one (that you could do yourself) for double the cost...but that really depends on your comfort level with doing that and your own preference...either way...shouldn't be a big dealio...just have to bleed the clutch system afterwards. How's the slave cylinder?
    I will see if I can get the instruction from my Haynes and type 'em in here...maybe take some pics. I need to do this as well on my car.
    I would rate this job (from 1-10) as a ...3? maybe a 1-5 scale...as a 1 or 2...it's not hard.
    Question...why is it you think you need to replace the clutch master cylinder? It is very common for the clutch slave cylinder to fail...if you are having difficulties with pushing in the clutch that is. Course...you may be like me...my slave failed completly, and the master will soon need replacing also, even though it has not yet failed 100%
    ____
      the first half of the clutch has no pressure and then it gets pressure. and sometimes i need to pump the clutch to gain pressure... also to turn on the car sometimes i need to pump the clutch a little .. seems to me like the master cylinder has a leak in it
        also, do i have to bench bleed the master cylinder just like a brake master cylinder? if do , how do i do this?
          I'd say the Mc is on its way to.
            does anyone know if i have to bench bleed the master cylinder ? and if so , how do i bench bleed it?
              bump
                yeah that sounds like the master cylinder is going out.
                You can bench bleed it but you don't have to, I'm sure you can do it on the car...but...don't quote me...I haven't done it yet
                ____
                  ok.... pour the fluid in... u dont have to close the lid. once u do that. u open the slave cylinder. not to much, just enough so the fluid comes out. have someone pump three times, it well start spittin out the fluid. on the third pump hold it down. n then u close the bleed hole, (slave cylinder) then, let go the clutch and then pump it ten times!!! u open the bleed hole. pump it 3 times again. n just do it over until its hard. and keep an eye on the fluid. add more. sorry for the bad english
