Auto Trans?????
    Auto Trans?????
    A while back my 91 EX simply stopped pulling ......no warnings....no codes...no trans light. Since I have been angry with it I have ignored it until today. I charged the battery and found that the starter motor engages and is turning what looks like the torque converter but the engine does not turn over. Has the converter separated from the flywheel???? What can I do to inspect it? Thanks!
    I will add that the day the trans stopped pulling the engine was still running. This supports the idea that there is a broken connection somewhere. Anyone??
      There is definitely something not working properly. Unfortunately, it looks as if you'll need to pull the trans to see.
        any directions on trans removal?????
          Unhook all electrical components. Drain all fluid. Pull your axles out of it (you'll need to pop the lower ball joints... be prepared to ruin them... torn boots mean they have to be replaced). Support the motor from the bottom using a padded jack (I used a good book). Lower the engine a little by loosening the driver's side mount. Undo the transmission mount completely. Remove all bolts holding the transmission to the engine. Pull. Don't kill yourself... that sucker is heavy.
            Thanks.....I have a jack and stands so that should help.
              To take the trans off you need to
              Undo electrical
              Take off intake/battery holder (makes it easier to get to stuff)
              Take out axles
              Take off kick down cable
              Take of shifter cable
              Take off starter
              Take off tranns cooler lines
              Take out VSS, or just disconnect the PS lines
              Take the bell house cover off (bottom)
              Take bolts out that hold the torqueconverter to the flexplate
              Take the main bolts out
              wat?
                Thanks! You guys are great!
                  I pulled the lower bell housing cover this morning to see of the flex plate and converter were still connected. They are! It appears the slipping is between the flex plate and the crank. Are there splines between the crank and flex plate?? Thanks!
