recently my clutch has been acting up. sometimes when i turn on my car and start driving i push on the gas and it takes long to get up to speed and the car revs back and forth. but after a few minutes the problem goes away and i could shift fine. also my clutch pedal has no pressure for the first half and then has pressure towards the end. could this be the culprit? or mayb its time for a new clutchh
clutch help!!!!!
clutch fluid reservoir was filled half way when i checked it today and i jus filled it to the top. im not sure if the car revving back and forth is a clutch master cylinder problem or the actual clutch itself
alone in this game . ::My Ride My Way::
Did you check your fluid level in the clutch master cylinder?
When you say it revs back and forth, you don't mean just at idle, correct? It's when you are moving? Can you give an RPM range?
I agree that you might need a new clutch, just trying to make sure.
EDIT: Beat me to it about the fluid level (typed too slow).1992 Prelude S w/swapped H22A
the rpms dont rev back and forth, the actual car does. it happens between 2500 and 3500 rpms. i push the gas and the rpms go up but the car goes nowhere. feels like its struggling to keep up.
Originally posted by tear2wothe rpms dont rev back and forth, the actual car does. it happens between 2500 and 3500 rpms. i push the gas and the rpms go up but the car goes nowhere. feels like its struggling to keep up.1992 Prelude S w/swapped H22A
yea especially since it's my daily driver. i rather lose it 4 a few days than for a few weeks. i was thinking with just getting an oem clutch from pep boys for about 100$. i dont want to get a performance clutch before i get my h22. do you guys think its a good idea?
Originally posted by tear2woyea especially since it's my daily driver. i rather lose it 4 a few days than for a few weeks. i was thinking with just getting an oem clutch from pep boys for about 100$. i dont want to get a performance clutch before i get my h22. do you guys think its a good idea?
OEM clutches really aren't bad if you only have a few mods. You could also look at this as the time to put the H in, if you have the funds.
If you are going to do the H soon anyways, you might not need to really care about what clutch you get. You could just get one to make it till then.1992 Prelude S w/swapped H22A
Originally posted by RacingEmotionsi personally wouldn't buy a clutch from pep boys. but thats just me
OEM from honda clutches are good, or Exedy, for mostly stock cars.1992 Prelude S w/swapped H22A
Originally posted by benjiI wouldn't either, but if he's going to get an H22 soon then he could go with a not as good clutch for now and save some money, and then get a nice clutch with the H.
yea. i dont need a permanant clutch since im going to replace it with a performance one later on. just one to last me for about a year or so
