suspension options
    suspension options
    im fairly new to the cb7 world but i have 3 different setups i can use for suspension on my cb7. 1st one is tokico hp struts with eibach springs. 2nd is kyp agx struts with h&r springs. 3rd is new but oem stock struts with ground control coilovers. what i want is a pretty decent slam without having any fender rubbing or problems like that but i want a decent stiff ride for racing. what do you think would be the best set up? i have all three set ups used and could mix and match if a better setup is between them. any input would be helpful thankks
    anyy suggestions?
      Welcome to the dark side. I have h&r sport springs with KYB AGX shocks.
        hows it ride. did it lower it any? im tryin to have it like2 finger cap from tires. right now i got stock steelies with tires. hoping for new ones in the future tho =)
          You can see mine by the link below. It has tokico hp struts with eibach springs. Works great for the street.
          Take that freek show to the park, maybe the squirrels will care.
            niice looks good with the body kit stance wise but i dont have one. im looking at getting a front lip but thats probably it for that. what size rims and tires are they?
              Suspension and Wheels
              - Ebackh Pro-Kit springs
              - Tokico Blue shocks
              - 215/45/17 Goodyear F-1
                nice looks good but prob going 16 when gettin rims for performance and summer street tires when buy them. trying to go a little lower tho. im still unsure onn what to useee hahaa
                  does anyone know if the ground control coilovers will work on either the tokico struts or kybs? ive read that they made certain coilovers for certain struts but im not sure.
                    I have "coilovers" (the sleeves that fit over the shocks meant for spring only) right now and am going back to drop springs with KYBs _ unless you're gonna shell out for true coliovers, I'd go with the Eibach springs and KYB or Tokico shocks.,
                    93 EX Arcadia Coupe, 5spd, f22a6, strut bars, 2"drop, baer brakes, ingalls camber kit, tokicos w/ eibach, K&N, 205s / 16s
                      I have tokico Hp and Eibach on mine. Rides great.
