Best ECU?
    Best ECU?
    For F22A6?
    what is the best one that will fit the F22A6 Engine and also give me the most performance?
    Originally posted by Zer0_92EX
    For F22A6?
    the one that is made for it, i dont know the numbers of the top of my head.
      there has to be others that you can switch into the CB7, other than the ones in it.
        Well, for the a1 and a4, they say use the p12. But the a6 has the IAB system, and with any other ecu's other than the p12, your IAB's are bound to not work. That's what they told me.
        98' Mustang 3V Swap
        11' VW CC R36
          oh ok, cuz my friend told me find out which one i can use and he'll help me with it cause right now its got like a PX0 in it and i dont have a freakin clue of what that is besides the stock ECU
            For F22A6?
            i'm sure you could chip a p28 or a p72 for it or something i dont know a lot about ECUs and tuning but you asked what one was best for your motor.
            the one that was made for your motor is the one thats going to make it run the best. unless you get a chipped ECU with it either street tuned or dyno tuned for your needs.
              trying to find one that can be tuned, i got friends of friends that can tune the crap out of them
              and my friend has a p28 in a 93 Civic EX and that thing roars with power, quite a bit of it comes from the ECU tuning
                The P28 in that Civic is the stock ECU.
                Honestly, if it doesn't have significant modifications, not much power will be had from tuning the ECU. If you don't have all the bolt-ons, plus at least a cam, it won't be worth your time. Tuning the ECU is only good for motors with AT LEAST a cam, usually headwork... or some form of forced induction. The best you'll get from a near-stock engine is better fuel economy (which is nice...)
                You have a PT6 ECU. As said before, it is the best one for the F22A6.
                The P12 mentioned is from an F22A1 powered Prelude, and will likely add about 10hp to the 125hp F22A1 found in the Accord... as it makes 135hp in the Prelude, and the ECU is the ONLY difference that anyone has been able to find.
                However, the F22A6 already makes 140hp. Much of that power increase is due to the intake manifold, which has a dual-runner (IAB) setup. The P12 from the Prelude wouldn't operate the IAB properly, meaning it wouldn't be nearly as much of an upgrade to the F22A6 as it is to the F22A1. You can hook the IAB up to vacuum only, but that doesn't make for efficient operation compared to the electronic control. It's debatable as to whether or not the P12 offers a gain over the PT6 tune anyway.
                If your engine is as stock as your car appears on the outside, don't even worry about the ECU. There's not much power to be had there just yet. Upgrade to a good header (Bisimoto is coming out soon), get an H23 intake manifold, get yourself a good cam (Bisimoto is best, a Delta regrind will work if you're cheap). Get a good exhaust system, and a cheapie intake with a good K&N or AEM filter. THEN you might see something worthwhile with a tune... but not a whole lot, even then.
                  what head u recommend?
                  and ill check into the h23 intake asap.
                  ill get the cam in a month or so
                    Head? F22A6.
                      I mean header sorry, bisimoto has been coming out with one for some time.
                      but I mean as of right now what header you recommend?
                        I'd wait for the Bisimoto. There aren't any quality headers for the F22A otherwise. What you have is about as good as anything else you can get. If you want a header, you're getting it just for looks.
                          k then, what else can i do to make my car perfrom better
                          this is what i know
                          Intake(already have on)
                          Exsuat
                          camshaft
                          cam gear
                          spark plugs & wires
                          Suspension
                          or a whole new engine.
                          anything else?
                            There are 5 years worth of CB7tuner threads FULL of suggestions.
                              If you replace that camshaft, lemme know. I need one from an A6, cause I just downgraded from an A6 to an A1, and that's all I need to make this A1 an A6 again.
                              98' Mustang 3V Swap
                              11' VW CC R36
