recently my clutch pedal has changed a bit. theres almost no resistance in the first half of the pedal when i push it down.. and then when i get to the other half theres very little pressure. almost like pressing the gas. I recently bled the clutch because the clutch hose got clogged and i replaced it , and that made the pedal hav a lot more pressure but now it's just gone. Then once in a while the engine keeps slipping when i shift gears but then i just turn off the car and turn it back on and everything is back to normal , and also today i tried to turn on the car and it wouldnt.. i pumped the clutch a few times and tried again and then it started. could this be i need a new clutch? i dont want to buy a performance clutch, at least not until i get my h22a .. that's when im going to start modding my car further. so would a regular oem clutch fix the problem or maybe it's something else i need?
Clutch trouble
Originally posted by tear2worecently my clutch pedal has changed a bit. theres almost no resistance in the first half of the pedal when i push it down.. and then when i get to the other half theres very little pressure. almost like pressing the gas. I recently bled the clutch because the clutch hose got clogged and i replaced it , and that made the pedal hav a lot more pressure but now it's just gone. Then once in a while the engine keeps slipping when i shift gears but then i just turn off the car and turn it back on and everything is back to normal , and also today i tried to turn on the car and it wouldnt.. i pumped the clutch a few times and tried again and then it started. could this be i need a new clutch? i dont want to buy a performance clutch, at least not until i get my h22a .. that's when im going to start modding my car further. so would a regular oem clutch fix the problem or maybe it's something else i need?
The clutch has nothing to do with the car not starting.
However, it sounds like the hydraulic system may be failing. Time to replace the master and slave cylinders (they don't cost all that much... best to do both, even if only one is failing). Be sure to bleed the lines properly. It's very easy to bleed a clutch line imporperly. If you aren't sure how to do it, have it done at Honda. They'll do it right.
If it's slipping while in gear, especially right after a shift, then the clutch may be shot. My clutch was riding on rivets when I finally changed it, and I still managed a 15 second quarter mile with it.
Pick up an Exedy OEM replacement clutch. That will be fine for an H22A as well. The H22 doesn't put out that much more power that you NEED to upgrade to a performance clutch. Don't waste your money on a part you don't need, unless you plan on some extensive work to that H22 as soon as you get it.
Here's my stock clutch... I'm sure it's the one that Mr Japaneseman got back in 1994 when he bought his Prelude...
[IMG]http://www.****.com/pics/deevclutch/rivetshadow.jpg[/IMG]
Originally posted by 90goldcoupeHave you looked at your clutch master cylinder and slave cylinder to see if there are any leaks?
alone in this game . ::My Ride My Way::
