So, got my car back today. Pretty sweet, until I went to put the system back in. o2 sensor's in my TRUNK in a BAG. What the hell!! Well, went back, cause they got 2 plugs mixed up, and my speedometer wasn't workin'. So, they fixed it and all, few minutes...just a mis-plug. Well, it's an engine from a 93' Accord. F22a1. That would be, either an Lx or Dx. I just read in the sticky for all the sensors, and it seems like the car's only have 1. Lx and Dx are in a different place than the Ex and the SE. My car's an SE, so they replaced my A6 with this A1 that I bought. Well, they told me they can't find the hookup to plug in my o2 sensor. Funny part is, the guy that put my header and exhaust on, said I had 2 o2 sensors. One by the flex-pipe, and one in the header. On the sticky, it says that the o2 sensor should be in the header (exhaust manifold). Where would the plug for the sensor be at on the engine? Figured it'd be in the front? For now, the place where the o2 sensor's supposed to be's plugged. Any ideas?
talked to the mechanic..
Well, I have a performance header. The guy that put my header on, said that the slot in the header itself, was too far for the sensor to reach, so he drilled a hole right in the header near the block, and did it that way. Hold on, lemme go take a picture of it for ya.98' Mustang 3V Swap
11' VW CC R36
ok... since you bought the aftermarket header for an a6 i would assume that it had the bung near the flex pipe to put the o2 sensor in which where it should have been to begin with. If you had an a6 in it then the plug for the 02 sensor should be next to the oil pressure sensor. This is all to be true if your mechanic used your original harness.
and further more i would have to agree... your mechanic is not the brightest of them all and should have asked your permission to relocate the sensor because he could have fucked something up.
