hey everyone, this is my second CB7. just purchased it on saterday and i've run into some problems.
1)the car seems to run fine in the morning when i drive but it seems when the engine warms up, the RPM wants to drop and bog down. in some cases causing the car to stall out. in results, me putting the car in to neutral and starting it up again. what could be the problem? (the car is an automatic)
2)i was just about to change the headlights when i realized that the driver side bulb was burnt out. i plugged in a set of HID's in and nothing. tried a regular bulb and the same results. would this be a bad connection plug? or a bad harness all together?!?!
3)when turning left or right i hear a knocking sound. on my last accord, i had the same problem and if i could recal, these cars have a CV joint problem? so im gonna assume it that?
any help would be appriciated!! number 1 & 2 is really pissing me off so i hope someone can get back to me on that one. thanks!!!
as promised, heres a pic!!
