i want more power
    i want more power
    I put in a Header, catback exhaust and cold air intake on my engine. Is there anything else i can do to get more power out of it. Its a f22a engine and auto tranny.
    Edited because our engines have 1 header, not 2...
    5spd swap..cams...pistons
    *Needs*
    -New shocks
    -Struts
    -Drop
    -Cleaning
    -New Tires/Wheels
    -New Window Tint
    -Alot more lovin'
      F22A1? F22A4? or F22A6?
      depending on the one you have there may be a chance that you can put an A6 camshaft in your car.
      and an H23 Intake manifold will help too.
      check out this thread. http://www.cb7tuner.com/vbb/showthread.php?t=88154
      Originally posted by kc8enb07
      does it come w/ jdm trash? they better throw away gold in it
        F22A is comparable to our A6. so... 145 hp?
          cheapest...f22a6 parts...
          expensive
          cam grind, chipped ecu, of course the butterfly intake and the intake spacer...
          more expensive
          build for turbo
          ____
            its an f22a6
              h23 intake manny
              93 Accord LX Sedan (sold)
                Boost!!
                92 DX, DSM setup16G,10psi..
                96 EK hatch built H22,GT35r 386hp 8psi pump gas,598 24psi on 110
                  manny
                  i say do the manny you will feel the difference
                    nitrous!!!! if u want to go fast and u dont want to go turbo
                    or go both
                    i just whent turbo and now i think i am going to get some nitrous this summer after i do some more work to the car like pistons and rings and cam new vavles then nitrous
                    93 EX COUPE, F22A6 turbo project
                    http://www.cb7tuner.com/vbb/showthre...45#post1615845
                    96 lexus sc300 DD
                    http://www.cb7tuner.com/vbb/showthread.php?t=143563
                    back from basic.... off to ait.... CB still being worked on i have mad plans for it .. sorry cant tell its on the hush hush for now but all i can say in somewhere around 500 hp soon to come..
                      help
                      true boost u can never go wrong but thats alot of money
                        No you need to research on the cheap setups that can adapt to the F. Boosting an auto is more work. People should research why.
                          f22a6 is still a pretty good bump than a standard f22a1
                          but a JDM H22a will be ur Biggest Bet
                          Ride: 2002 Lexus IS300
                            Does anybody have dyno sheets of what a F22a1 with I/H/E + A6 cam/ECU + H23 manifold?
                            wat?
                              I dunno about cam and the h23 manifold but most of the dynoes I have seen posted up by members are 115-119 ish whp but like 125 ish tq. I forgot but some people have there stuff posted. This was for a 5 spd.
