Well went to go get my tune up and oil change and found out that my seals around my timing belt were the old ones since they changed it awhile bak so i used all my money to pay for the parts, cost me my entire paychek.Apparently whoever changed my timing belt kept the same seals and so oil got into my spark plugs and on my timing belt. Plus my O rings were soaked and wee bout to break. WTF!!!!
Oil Leak????
the seals that are changed during a timing belt job have nothing to do with oil on the spark plugs....oil on the spark plugs is from the spark plug tube seals....the upper ones are easy to get to...you just have to remove the valve cover...the lower tube seals are underneath the rocker arm assembly.
