Im trying to remove my ball joint which i have done before on my other cb7 but this time im having problems. When i try to loosen the nut it doesnt move. when i use a breaker bar it just spins the wholeball joint. tried pb blaster ?? What do i have to do?
Ball Joint
Upper - Remove the cotter pin, and get the crown nut a couple threads on, whack it hard (if the ball joint is shot, you wont be re-using it anwyays) Ball joint spreaders are nice to have, its an oversized 2 prong fork. you shouldnt have any probelms, i just did all my uppers. What a difference.90 Accord EX F22a1 Auto R.I.P.
2011 Mazda 3 Hatch 2.5L GS sport HELLO!
Originally posted by Bcozzi71Im trying to remove my ball joint which i have done before on my other cb7 but this time im having problems. When i try to loosen the nut it doesnt move. when i use a breaker bar it just spins the wholeball joint. tried pb blaster ?? What do i have to do?my daily driver. (AOM June 2010)
"she may not look like much, but she's got it were it counts kid. Made a lot of special modifications myself."
MR page
http://www.cb7tuner.com/vbb/showthread.php?t=76111
The fork will almost always destroy a boot... especially an old, worn boot. If it's already ripped, it's worthless anyway. If it's not ripped, you'll rip it, rendering it worthless.
Let the PB Blaster soak in. If it still won't come loose, try holding the bolt with something. Just be careful not to damage the threads.
Originally posted by Bcozzi71its the lower balljoint. Im trying to take the axle out. yes the cotter pin is out. Im gonna try to get some air tools b/c this balljoint is only few months old. Thanks for the help guys.my daily driver. (AOM June 2010)
MR page
I just had this problem with the LBJ spinning with the nut when I was trying to put everything back together after an axle swap. Nearly went insane.
The fix:
Make sure nut and LBJ thread are completly clean, with no burrs on the metal.
Put a small pry bar against the fork. Pull down on it to put pressure on the top of the LBJ.
Nut goes on.
Since you are removing the nut you have the opposite problem. Can you use a jack to put upward pressure on the LBJ?90 Accord Ex, F22A4. Slight fire damage.
