Help!!!!
    Help!!!!
    Thankz so much cb7 for great advice. After spending $ on my appearance .I'am ready for a major upgrade on my stock 91 ex motor . I'am considering a h23a nonvtec recommended of cb7 called jdmtigerjapanse.com 1 st question iz this A good motor?? 2) I'd this also a good site ??and how much am I looking at toward getting this put on in a shop ??
    yes
    yes
    call them ( every area will be different )
      sounds like a great setup.. Maybe a little turbo on top of that..
        The h23 is nice, make sure to get the h23 or 22 transaxle, you wont regret it, you will fill a nice bump in horsepower. on a side note have you considered doing the h23 intake manifold swap?
        Click Me
          you could also do this swap, it's a bit easier than the h22 swap, but tigerjapanese.com is whre im getting my h22 this wedsnesday, good luck with your build
            I'am a rookie what's the transaxle ?? And the intake manifold what would the I get that from ???
              we have a transmission and an axle all in one so its called a transaxles most just call int a transmission just depends on how you want to say it. Also you could get the intake manifold from an h23 or order off ebay an h23 manifold. But before you commit fulley to anything I think you should read this and also this I think they will really help you out. The 1st couple of times i read them they helped me a lot. Lastly one of the biggest things you can ever do is learn to search on your own, ( not saying you didnt look 1st) and look threw the members rides section I know there are many people who are making major power out of the f22. the 3 best ways to make power are as follows maintain your car i.e. spark plugs, wires, cap and rotor etc. 2nd intake header exhaust, 3rd is your catalytic converter go for a high performance one like a random tech, however dont get the "high flow" cats off ebay there just a cheap resonator.
              ok i will get off my soap box now.
              Click Me
