Soft pedal when braking????
    I did a rear disc conversion on my 90 Accord EX. I changed the master cylinder to a 1" I got a proportioning valve from a 90 Integra (40/40) I have new calipers all the way around. Now when braking the pedal is soft. When I looked at my rotors after a while the rear still look new while the fronts look obviously used. I thought the master was bad so I had it changed at a local shop and in doing that they bled the brakes several times. After that the pedal is still soft. Anyone have any idea on what is going on??? Can a proportioning valve be bad?? Or maybe the brake booster bad??
    The brake booster would make it really hard. Do you have abs?
    -1991 Honda Accord LX H22a-
      I do not have ABS
        ur calipers may be bad or air in the lines
        current cb 93 10th ann. edition
        member ride thread >>> http://www.cb7tuner.com/vbb/showthre...73#post3257973
          yeah prob air in the lines if the pedal isn't sinking to the floor
            Hope not the calipers are brand new and the brakes have been bled probably 5 or 6 times this last week.
              make sure all ur lines are tight or just get new ss ones they make a difference even the ebay ones i got those and they do great no leaks or nothing had them on for about 9months now
                Tight for sure...local honda shop did the last couple of services. Brake lines are new. Possible proportioning valve?? What about booster?? The shop rec'd these parts again I just want a second opinion.
                  i guess the jist of it is that everybody has already said it air in the lines which is questioning did you bleed the breaks
                  ..."CLASSIK"-CB790 ex... {UNDEFINED}My Classy but Sick (Classik) Black on Black Members Ride Thread
