well i picked up and a6 camshaft for like 10 bucks at a junk yard and i put it together and the car cranks but wont start
car wont start after i changed the camshaft
Does it turn over? if so are you getting spark and fuel? Check engine lights? Double check that the head and block are both at TDC when they are supposed to be.Knowledge is power...in EVERY sense of the word
Ok, so that's probably fine. Are you sure your battery cables are clean? (sounds stupid, I know... but I spent $300 on new parts one time, only to find that dirty cables were the cause of my no-start situation!)
No start, but cranking, can only mean two things... no spark, or no fuel.
Pull a sparkplug, but leave it attached to the wire. Hold it near something metal, and have someone crank the engine. Look for spark. Then smell for fuel at the empty sparkplug hole. If you see spark, your ignition is working... so it's probably a fuel issue. If it's a fuel issue, look first to the main relay, then the fuel pump.
If you get no spark, then look to your distributor cap and rotor (cheap). Then your igniter (not as cheap), and then your coil (more expensive yet)... Finally, the distributor itself (cheap! not...)
Of course... as mentioned above... did you properly align the cam gear for the correct timing? Do you have cylinder #1 at TDC on both the cam gear and the crank pulley?
The ignition timing itself won't really affect starting, but the mechanical timing will.
