CB vibrates!
    You might want to try adjusting your idle speed as well. With the motor fully warmed up, disconnect your IACV (the only thing with an electrical plug on it, right on the front of your intake plenum), then adjust the idle screw on your throttle body until your idle is at 550 rpm. Turn off the car, plug the IACV back in, disconnect the battery for 10 minutes to reset the ECU. Go ahead and start your car, it should idle around 750 rpm or so now, in and out of gear.
    This solved a lot of my vibration issue.
      Thats just how it is. How often are you in reverse anyway?
      wat?
        thanks for all the suggestions guys!i think ima have to take a look at the motor mounts this weekend.hopefully it wont be to hard?maybe a diy would help?another question would the tranny fluid some how relate to my situation?would it be a good idea to flush it change the gasket and the filter?thanks.
          If the motor is vibrating harshly then new mounts won't fix it, and may possibly even transmit more of the engine's idle vibration into the chassis. If you're idle speed is too low then you have to address that, not the mounts.
          Worn / broken mount rubbers will be more of a problem when getting on and off the throttle, as they will allow the engine to rock back and forth under positive and negative torque loadings.
          Regards from Oz,
          John.
            If anything broken mounts dampen more as they are easily moved around and arent really connected to the engine
            Your man for wiring solutions!
            CB7Man's Coupe H22 Swap
            CB7Man's Sedan Resurrected From The Dead
              Why would you think they dampen more? The point of a mount is to dampen and the older they get they transmit lower frequencies... so even if they arnt shredded they will still be transmitting lower frequencies because they are harder or broken or whatnot... Mounts are very special they just arnt pieces of rubber there for no good reason. and yea they are connected to the engine? they isolate the powerplant from the body.
              I seem to go through mounts on my cars every 100-150k they arnt too expensive and they are relatively easy to replace. How often do you replace shocks on a car? same principal. stuff wears out.
              AD5OS
              FOLDING@home
                RPM too low obviously
                Any car will vibrate (Especially a I-4) at 300-500 rpms
                Mine does it, albeit very little it seems to like idleing at 350
                Whats your hot idle in Park?
                I've never heard of any automobile engine being able to idle at 350 RPM... That said, the tach only goes down to 500.
                Mine vibrates at about 700 RPM... but since I swapped the ECU it's been idling at about 800 which is about perfect.
                1991 Accord LX, 2Dr, 5 Spd, P12 ECU, Ebay Short Ram, Megan 4-2-1, Full 2.25" Ebay Exhaust + 60 Series Flowmaster.
                1987 Camaro IROC-Z/28, 350 Crate, 700R4, 2.73 Posi, Edelbrock 1406, Edelbrock Performer Intake, Summit Headers, 3" Catco Cat, 3" Hooker Cat-back, Pioneer DEH-7800 HU, 600W Pioneer Amp, 350W 10" Pioneer Sub + 6 Pioneer Speakers.
                  Originally posted by Opticon
                  mine did the same thing yesterday, come to find out my bass knob was up too high lol.
                  lmao..... funny funny
                    I have a vibration problem too... but its only when im cruising in 4th gear (Auto) at about 2.2k-2.5k revs @ about 80km/h.......... vibrates alot when im going slight inclines.. .ask my mech friend and he said it was the lack of low end power......any idea guys?
                      Originally posted by 91CB7650
                      hello my fellow CBtuners! okay heres my problem my whole car vibrates when i put her in gear.say its in park and i put it down to reverse it vibrates like crazy!idk why?and also when shes in drive and im at a stop the car would vibrate.its gets annoying.what could be the problem?motor mounts?just guessin.thanks in advance
                      Exactly how mine was when I bought it. I'm sure it was the reason it was for sale.
                      Bought all 4 engine mounts on ebay.
                      The front one was completely shot and the new one helped some, replaced the right side a little later when I had time, again it was better. Replaced the left one a couple of weeks ago when I did the timing belt and set the valve lash replaced wires.plugs,cap and rotor and vibration is almost gone. almost.So much better it's like a different car. The ebay left side mount had to drilled out on the front mounting hole to fit. Not a big deal.
                      The front, left and right mount can be replaced without digging to deep,hand tools and jack to keep the engine in place is all you need. The rear one is more involved. when you look close you will see what I mean.
                      Take that freek show to the park, maybe the squirrels will care.
                        Mine has the same problem, it vibrates only when in gear at a stop. I'm gonna wait till I do the swap and change all the mounts.
                          motor mounts would be the first thing i'd check
                          Revtech Motorworks
                          Sonnyvan Auto Body
