hello my fellow CBtuners! okay heres my problem my whole car vibrates when i put her in gear.say its in park and i put it down to reverse it vibrates like crazy!idk why?and also when shes in drive and im at a stop the car would vibrate.its gets annoying.what could be the problem?motor mounts?just guessin.thanks in advance
CB vibrates!
first thing to check would be motor mounts. That is a big contributor to vibration.
Originally posted by Georgia93coupecould be the heat shield on your catalytic converter. ive heard of that problem many times.
If it's an automatic I would check the rear motor mount. The automatic rear motor mount is hydraulically controlled to reduce the vibrations by opening up a secondary chamber, or something like that, so it becomes softer at low rpms. They have a tendancy of going out, mine used to vibrate like crazy too, replaced the rear motor mount, and it's all good now.Originally posted by 92dmI was actually just being a smart ass, and not really contributing to this at all.
Bought from: cb95spd
Originally posted by Opticonmine did the same thing yesterday, come to find out my bass knob was up too high lol.
91CB7650 you're on the right track thinking its your motor mounts. does the vibration only occur when in gear or does it happen in park as well? if it only happens in gear, its the motor mounts (most likely the rear one). and it happens even when out of gear (neutral/park), i dont know what to tell you90 EX DUMPED!!!
hi I'm having the same issues as well so I did a used part search and have had about 20 different used parts places around quoting me around $60-70 for all 3 motor mounts. I really wanted to get some junk mounts that are craped out and do some urethane inserts and try out some 60shore mounts and see if they work better... Figure its worth $20-30 buts for the attempt. Those hydrolic fluid mounts I remember being a problem on my 93EX and cost something like $200 in the late 90s to repair.AD5OS
FOLDING@home
