HELP PLEASE... weird noise
    yesterday my 93 ex (canadian model) started to make a gringing noise when i drive its a steady noise it only goes away when i turn right whats wrong i have looked and i can't figure it out my boots are all fine i know my wheel bearings need to be replace but it sounds like its coming from the middle of the car but i could be wrong.......
    i did a search and didn't some up with much...
    ok i changed my breaks today and noticed my right front wheel bareing is bad would that be the noise cause it sounds like its comming from the middle but sounds travel.
      Yeah, I gotta say that's your noise. It goes away on right turns because the weight shifts to the left wheel more.
        Yes, that would be it. If you jack up the car (from the rad cradle) and put it on jack stands, put the car in neutral. go to the front wheel, and see if it makes a grinding noise. If it does, there is the problem.
        Good luck
        90 Accord EX F22a1 Auto R.I.P.
        2011 Mazda 3 Hatch 2.5L GS sport HELLO!
          You solved your own problem. Thats called wheel bearing is about to take a shit on you DO NOT DRIVE THE CAR ANYMORE. When wheel bearings decide to finally let go its not pretty. Get it fixed. You need to press it out and then replace it with the new one. Spinnin the tire will not always find the problem since there is no load on the tire. Anyway replace your bearing before anything bbad happens.
