ive looked it up and cant seem to find whats causing my no spark problem. first i had no spark to only one cylinder but now its not getting spark to any of them. ive replaced all the plugs, wires, cap and rotor. ive even tried changing the ignitor but i still dont have any spark. is there a way to test the internal coil? i cant find anything on how to test it.
no spark on all cylinders
There's a certain resistance that the coil is supposed to provide which you can test with a multimeter... I don't remember the spec, it's something like 15-18k ohms... but don't take my word for it. If you haven't already, you should get a haynes manual for your car at your local auto parts store... they've got the testing proceedure and specs described in there.1991 Accord LX, 2Dr, 5 Spd, P12 ECU, Ebay Short Ram, Megan 4-2-1, Full 2.25" Ebay Exhaust + 60 Series Flowmaster.
1987 Camaro IROC-Z/28, 350 Crate, 700R4, 2.73 Posi, Edelbrock 1406, Edelbrock Performer Intake, Summit Headers, 3" Catco Cat, 3" Hooker Cat-back, Pioneer DEH-7800 HU, 600W Pioneer Amp, 350W 10" Pioneer Sub + 6 Pioneer Speakers.
Originally posted by ChillPhatCatThere's a certain resistance that the coil is supposed to provide which you can test with a multimeter... I don't remember the spec, it's something like 15-18k ohms... but don't take my word for it. If you haven't already, you should get a haynes manual for your car at your local auto parts store... they've got the testing proceedure and specs described in there.
this is the h22 im having problems with not the f22.Last edited by jrlavey; 03-08-2008, 01:03 AM.
Ignition Coil Test (Fuel-Injected Engine)
1. With the ignition switch OFF, remove the distributor cap.
2. Remove the 2 screws to disconnect the BLK/YEL and WHT/BLU wires from the terminals A and B respectively.
3. Using an ohmmeter, measure the resistance between the terminals. Replace the coil if the resistance is not within specifications.
NOTE: Resistance will vary with coil temperature; specs are at 20*C (70*F)
Primary Winding Resistance (Between the A and B terminals):
0.6 - 0.8 ohms
Secondary Winding Resistance (Between and A and secondary winding terminals):
12,880 - 19,320 ohmsLast edited by demortey@mac.co; 03-09-2008, 11:16 PM.
Igniter Unit Input Test
1. Remove the distributor cap, the rotor, and the leak cover.
2. Disconnect the BLK/YEL, WHT/BLU, YEL/GRN and BLU wires from the igniter unit.
3. Turn the ignition switch ON. Check the voltage between the BLK/YEL and the body ground. There should be battery voltage. If there is no battery voltage, check the BLK/YEL wire across the ignition switch and the igniter unit. If there is voltage go to step 4.
4. Check the voltage between the WHT/BLU wire and the body ground. There should be battery voltage. If there is no battery voltage, check the ignition coil and WHT/BLU wire between the ignition coil and the igniter unit. If there is voltage, go to step 5.
5. Check the YEL/WHT wire between the PGM-FI ECU and the igniter unit.
6. Check the BLU wire between the tach and the igniter unit.
7. If all tests are normal, replace the igniter unit.
Hope this helps....
