We went to buy a used 94 accord tonight. This is the first time i've driven a vtec car, but ive riden in quite a few. At first i felt the vtec come on strong and the car pulled hard. After a few mins, it seemed like the vtec wouldn't come on at all.... it was having trouble getting to red line in 2nd gear (5-speed). stopped, the red-liner will work great just like my cb7, but in this car, while driving once it got to about 5700 RPMs it was like it hit a governer, all power was lost...... i shifted and some power was there but no vtec.... every once and a while i felt like it came on for a second but not long. Ive read about about the vtecs not coming on while low on oil, and i checked the oil on the car and it seemed quite low. Lower than i would ever go. He said he would put some in it and check.. i think its an f22b1 SOHC vtec. Any ideas? should he stay away from the sale? oh and it seemed like his alternator was weak, the headlights were dimming alot at random times. sometime under acceleration. sometimes not. Any ideas?
Vtec probs.
The F22B1's vtec system is totally different than any performance-oriented DOHC system. If you've only experienced an H22 or B18, then you may not notice the F22B1.
I don't believe it breathes very well up top anyway... though from the sounds of things, there's something wrong with it. IMO, the F22B1 is garbage anyway... at least from a performance standpoint. If the car is just to get from A to B, go for it... but only if you're comfortable with what it's doing. I would just stay away.
also check the oil pressure switch if all else fails
no
Accord turbo kit under $2k here
$30 HID kits here Thread
"What a selfish bitch. She looks like one too. A smart-mouthed, facebook-ing, "i dont know if im straight, bi or *** yet" little brat." -greencb7inkc
"No Herra Frush, Slammed, tucked or frame dragging here. I'll leave that to the mini trucks...." -fishdonotbounce
My f22b1 in my 95 accord sucked balls. My head was ported so at 6k mine totally died off. those motors just don't breathe up top and if you were feeling vtec hit then something is going wrong and it is not hitting at 2500 like it should.
That motor happened to make 5 hp over the a6 but it was totally designed for gas mileage. And after I studied my b1 head in my garage the other night, I'm not even sure that there is really a high cam vtec, it is just opening both intake valves after 2500. My opinion, stay away... unless you have plans to swap it.vouch for:924dr, sn2bh22cb7, soysaucecb7, ecto1, PRIMESNIPER,2.2litrebeater,turbowagon94, losiracer2,jacobuchanan140, tommi, dannyd
Ok, Its not throwing any codes at all. the Car seems to pull really strong when i did feel the vtec. it didn't seem to kick in until about 4000 tho. and it was like big time feel it too... compared to an 07 civic si, i could barely feel the si compared to this. The oil was low and its got 183000 miles on it.... He really likes the car and its got a short ram CIA so.... its kinda odd.he said it got 33mpg so thats good. I dunno. Kinda confused....COOL!!! < My Ride> '93 EX F22A6
Originally posted by turbotoot2why would it not work ,use a p28 on it and tune it
If the oil is low, that's probably the reason for no vtec. It may have hit hard and high in the RPM range because you were already well into vtec territory by the time the oil pressure got to be enough (assuming a pressure rise at higher RPM)
If the oil is low, there's also a reason for it. Leaking or burning. Now you have a car that loses oil, that's being driven low. 33mpg IS possible. The F22B1 isn't a great motor, but it's pretty good on gas.
Honestly, unless you plan on doing some work to this car, I wouldn't get it... unless you can get it quite cheap. It sounds like that motor might have more issues than it's worth.
The F22B1 has barely kick in the pants vtec. Some people say it makes a difference with a p28 and with it tuned. I cannot say since I have not rode in one with a chipped ECU. My friend had a b1 and vtec controller. Too bad it was auto and later on got stole. But anyway that car wasnt all that quick. Looked damn good but it was slow sorry to say. But yea VTEC not engaging could be quite a bit of things...
1. Bad wiring
2. Low oil level/pressure
3. Dirty Solenoid
4. Engages in 25mph<*
5. DOES NOT WORK IN NEUTRAL
thats all I can think of for now.
