my ecu is flashing code 14 ,i know that is the ivac malfunction ,ok code 43 is my o2 sensor ,what is code 15 ,ignition output signal mean ,how do i fixx code 15 ,what does it mean ,is it my dizzy ,going bad ,had that replace about 1 year ago ,could it be bad already , thanks for the help
code 14 -15 and 43
14 probably needs cleaning of the IACV
43 is the fuel supply system , not the o2 sensor. You probably not getting enough fuel in the system.
15 check your distributor
1996 Honda Civic LX 2009-2012
2012 Kia Optima LX 2012-2013
code 41 is 02 sensor. If your code is 43 then its fuel supply system!
now that being said usually replacing the 02 sensor fixes the problem but it could also be a short in a wire or a bad ECU.Dave Estes (owner of) DB Customs & Automotive Repair
http://www.automotivecustomworld.com
Just check it out!!
free people search http://www.dbcustoms.ws
