fuel pressure regulator
    i wanted to know what does it do? does it save gas or not?
    http://www.autopartswarehouse.com/de...A1825300R.html
    The Fuel Pressure Regulator regulates the fuel pressure. The computer does not control the FPR; it is controlled by engine vacuum. There is a vacuum line that goes directly from the intake manifold to the FPR. Inside the FPR is a diaphragm with a valve. At idle when engine vacuum is high, it opens the valve lowering fuel pressure. At higher RPM's when engine vacuum is low, the valve closes increasing fuel pressure.
    Freedom Is Not Free
    U.S Army 02/08 Medically Discharged
      If you dont have mods to back it up and I dont mean basic I/H/E you need to use it with a power adder. The basic easy answer is your wasting money.
