fuel problems
    fuel problems
    ok guy i jut bought a cd5 with a jdm h22a engine , i just wanted to know how much gas does a h22 usually waste because mine is doing horrible in gas milage
    You need full tune-up my friend.
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      what kind of tune up exactly because i got msd ignition coil and wires maybe spark plugs could do for a changing and fuel filter but other than that...... idk......the oter day i put $25 in gas which equals pretty much 8 gallons here in miami and it filled up to a quarter before full tank and now it has less than a quarter to empty with only 80 miles so its like 10 miles to a gallon its like im driving a freakin hummer
        What kind of ECU are you running? Are you throwing any codes? Does your car run like shit?
          maybe a leak in your gas tank.
          My signature works perfectly fine.
            If it's a leak, it's a big one and it should smell real bad. I had a small leak on mine and I could smell it all around the parking. It also leaves an embarrassing dark spot under your car.
            Accord EX (Can) 1993 296 000km
            Winter 2008
              I'm going with bad O2 sensor or wrong ECU... maybe a badly regulated fuel pump... If it was a gas leak of that proportion, I'm guessing you'd smell it.
              Off the top of my head I'd guess you'd get at least 25 MPG highway with that thing.
              Does the car give off black exhaust while you're driving or if you floor it? Does it have the power you'd expect? Any detonation that you can hear?
              1991 Accord LX, 2Dr, 5 Spd, P12 ECU, Ebay Short Ram, Megan 4-2-1, Full 2.25" Ebay Exhaust + 60 Series Flowmaster.
              1987 Camaro IROC-Z/28, 350 Crate, 700R4, 2.73 Posi, Edelbrock 1406, Edelbrock Performer Intake, Summit Headers, 3" Catco Cat, 3" Hooker Cat-back, Pioneer DEH-7800 HU, 600W Pioneer Amp, 350W 10" Pioneer Sub + 6 Pioneer Speakers.
                Sounds like your method of tracking mileage may have some error built in... what you should do is fill it all the way up and drive it maybe 100-150 miles and then fill it all the way up again and see how much gas it takes... then divide miles by gallons it took to fill.
                  yeah ^^^^ what he said, then you can get some baseline numbers for MPG and work from there. But since you JUST got the car, it wouldn't hurt replacing a few basic things: air filter, oil change, spark plugs, wires possibly, fuel filter, tire pressure check....all those things add up
                    well i work at goodyear so everything maint. wise is covered and i do get the power id expect from it cant really smell gas but i do get a code but when i turn off the car it goes away havent really checked i out yet all i really know is that im gettin 217 at the wheels
