ERg frustrated.
    ERg frustrated.
    So i took my valve cover off to paint it,
    but when i was putting it back on the gasket wouldnt seat right,
    so i kept getting mad and i snapped off one of the studs that holds on the valve cover,
    how can i replace that stud,
    and what should i do about my gasket
    J | D | M
    "Sohc, one cam less, one cam lighter"
    Vtec is overated anyways
    get an ez-out for the stud. I think they have a cheap version of it at Autozone, just put it on a drill and it'll pull it out.
    what exactly is the gasket making the valve cover do? is one area raised more? make sure it's not twisted on there funny. take it off and make sure there's nothing up in one of the grooves.
    also, don't get frustrated and break off any more studs.
    Former: 90 LX, 91 EX. Current: 92 LX
      haha, alright thanks man ill go check it out,
      but it might be on there twisted, it seems likes its almost too big.
      J | D | M
        might take it back and make sure they gave you the right one.
          where did ou get the gasket? i recently got a valve cover gasket for my 91 accord and it was too big (a duralast from autozone) it was like it had been stretched out and would not fit right. ask them for a more expensive different brand or gt it some place else. hope you get it solved!
          or where you re-using the original gasket? that could be a problem too.
          Dave Estes (owner of) DB Customs & Automotive Repair
          http://www.automotivecustomworld.com
          Just check it out!!
          free people search http://www.dbcustoms.ws
            yea re-using your old one will make it seem stretched out. Persoanly, i would go with OEM gaskets. Not that aftermarket oem bullshit.
              yeah i had an issue with the damn autozone duralast shit too.....it did seem like it was too stretched out. But as mentioned.....i went to the dealership to be sure i got it right the next time.
                first time instl of the duralast valve cover gasket went without a hitch, but after adjusting valves and cleaning the gasket, it stretched. SO we cut it in 2 spots along the long sides and used black rtv silicone to seal it all up. Never leaked after like 3000 miles or so. Make sure you seal the corners by the cam seals with silicone too. It likes to leak in those 4 areas.
                Check out ESP engine mount kits for your CB7!!!
                  use some siolcone or any adhesive to make the gasket stick to the cover.
                  miss my turbo cb7
