How to Improve Gas Mileage on a 2001 Honda Accord
    Hi everyone,
    I am a new member here and need some advice. I have a 2001 Honda Accord and recently I have noticed that my gas mileage is not as good as it used to be....
    I am not sure if it is because of the age of the car or if there is something I am missing. I regularly change the oil and have kept up with basic maintenance but I am looking for tips or tricks to improve my fuel efficiency. Are there any specific parts I should check or replace. Maybe some driving habits I should adopt or avoid. I would appreciate any suggestions or experiences you all could share.
    I also searched this topic on this site https://www.hondaaccordforum.com/forum/general-tech-help-7/improve-gas-mileage-golang but I could not found anything helpful for me.
    Thanks in advance.
    Best,
    [Smith]
    I'd recommend proper tire inflation, good oem spark plugs, driving slower. Wind resistance makes a huge difference in gas mileage. If you don't mind speeders whizzing by you on the freeway/highway, keep to the speed limit or slightly slower.
    My swap thread
    Main relay proplems?--DIY
      Yeah proper tire inflation. I would replace the rubber vacuum lines also, in the engine bay, with silicone vac lines.
      Also replace the spark plugs and wires if they are original. And replace your fuel filter and use at least 89 octane. There's a reason why turbo car guys use race fuel, its much cleaner.
      Also check your pcv valve and probably change that out if it's original. And you could also look around your fuel injectors for any build up and if there is, consider replacing fuel injector o rings.
      And, last but not least, with the vehicle on a lift or jacked up, spin your wheels by hand, make sure they spin freely, the point is to make sure that your brake calipers are not sticking. Or you could remove each wheel and inspect your calipers and brake pads for even wear.
