First Accord, Many Other Hondas
    Bought a cheap '92 Accord a couple weeks ago with a knocking engine:
    Started tearing into this weekend and found the source of the knock:
    I see j00!
    Sourced a ridiculously cheap H22 engine and trans locally through CL, so that is the plan at this point...along with freshening up what I can on my budget.
    Thanks to lucid's thread for help on what parts are needed!
    I'm trying to swap the F22 distributor internals into an OBDII distributor housing...looks like all I'll need is to drill and tap a couple of holes for the CAS pickup.
    Hondas of Christmas past:
    Current:
      Behold the Honda Doppelganger...
        huh.... I wonder why it knocks...
        nice S2K
        C-3PO's MRT USDM yo!
          I really wanted to pull the head off the A6 to see if took any damage, but the head bolts are on tight enough that 1/2" impact wouldn't budge any of them except for one of the middle bolts. Tried a breaker bar with a 4 ft jack handle as a cheater and still no dice...
          I've stripped about all off the A6 that I can use and it will get tossed in the scrap pile.
          Need to order parts for the H22 so I can complete it and get it ready to go in the car.
            Very nice shop you have there.
            Project:Black Skittle
            AOM->April 2014
            MRT->http://www.cb7tuner.com/vbb/showthread.php?t=199779
              Seeing if I can convert the OBDII H22 distributor to accept the OBDI F22's guts.
              3.3mm drill bit
              M4x0.7 tapered tap
              M4x0.7 bottoming tap
              drill press
              and
                LeMons racer, eh? Can't wait to see what you do with the Accord, you guys are a thrifty bunch. Are you on the GRM forum as well?
                '98 Prelude resto/mod thread
                  W A G O V A N !!!
                  Miss my crx
                  Pop vTec
                    Originally posted by SunkistCB7 View Post
                    W A G O V A N !!!
                    Miss my crx
                    Is it sad that I was most excited to see the wagon? I miss my RT. It unfortunately had the typical RT rust issues, including the rear crossmember almost losing a lower control arm. There aren't many Hondas in general around here, especially in the wreckers, so I ended up selling it to buy my 92 so I had a reliable daily
