Why is there a high pitch noise when the rpms raise? Is there a way to get rid of this? I have checked the grounds.
Why the high pitch sound when rpms raise?
Originally posted by deevergote View PostWhy are you asking a question about your car in the Off Topic section?
And where is this sound coming from? The engine? The transmission? The speakers? Your ass? We're not in your car to hear it, so you have to give us some information.
I might be off so don't quote me, but it may not be grounded right or two wires touching?
I'm also quite sure it's a wiring issue. Do you have an aftermarket CD player? I assume you do, since you mentioned MP3s. Are your wires spliced, or are you using an adapter harness? If the wires are spliced, go in there and make sure everything is properly shielded. If you used a harness (ALWAYS a better option than cutting your stock wiring), then make sure it's in good condition. It's possible that the harness is made of cheap materials, and the wire sheathing isn't all that great.
However, I occasionally get a whine from my speakers in my 09 Fit when my iPhone is plugged into the stereo system (via the line-in). I'm not sure if it's due to my currently failing OEM stereo, or the $5 wire I picked up from Wal Mart to connect the phone to the car.
Originally posted by deevergote View PostI'm also quite sure it's a wiring issue. Do you have an aftermarket CD player? I assume you do, since you mentioned MP3s. Are your wires spliced, or are you using an adapter harness? If the wires are spliced, go in there and make sure everything is properly shielded. If you used a harness (ALWAYS a better option than cutting your stock wiring), then make sure it's in good condition. It's possible that the harness is made of cheap materials, and the wire sheathing isn't all that great.
However, I occasionally get a whine from my speakers in my 09 Fit when my iPhone is plugged into the stereo system (via the line-in). I'm not sure if it's due to my currently failing OEM stereo, or the $5 wire I picked up from Wal Mart to connect the phone to the car.'94 CD5 EX F22B1 Automatic
