I still am deciding on what to do to my car next and im faced with these two TSX retrofits or lowering the car??? my car is on stock suspension and i want to lower it but i would really like to retrofit my headlights... any advice
Cant decide: TSX retrofit vs Lowering
MR : http://www.cb7tuner.com/vbb/showthre...ght=CB7+R3ason
Originally posted by quaidumyou being able to see four blocks down the road is resulting in someone not being able to see 5 feet in front of them
good job, just what the world needs more inconsiderate driversTags: None
Do one, save up, then do the other...?
Originally posted by JarrettIs there a goal you're trying to accomplish besides looking dope as hell?
how do you do a retrofit is there a diy
Originally posted by keepinitcleanI give it 2 weeks before you sell it.
Lowering your car will most likely give you the most satisfying mod for now. Its something that you will love every time you walk out to your car, front, rear, side...the "look" will always make you happy...the headlight mod....what ever that is will not be near as noticeable to you after the newness of it wears off, most people will never notice it and its not something that will impact the entire look of the car like a drop will.
Originally posted by Noridetoolow View PostLowering your car will most likely give you the most satisfying mod for now. Its something that you will love every time you walk out to your car, front, rear, side...the "look" will always make you happy...the headlight mod....what ever that is will not be near as noticeable to you after the newness of it wears off, most people will never notice it and its not something that will impact the entire look of the car like a drop will.
1990 Honda Accord Sedan
1998 'Slammed' Ford Crown Victoria LX
What would you lower it on? Lowering is the more expensive option, and it's really not safe to halfass it. If you can't afford to lower your car safely, and you absolutely MUST modify your car ASAP, then I say do the retrofit.
The 3 things I love about my car are my H22, my suspension, and my retrofit. Oh, and my paintjob. That's all I really need... just those 4 things.
Originally posted by deevergote View PostWhat would you lower it on? Lowering is the more expensive option, and it's really not safe to halfass it. If you can't afford to lower your car safely, and you absolutely MUST modify your car ASAP, then I say do the retrofit.
Function over form man...
Lou's Build Thread!
http://www.cb7tuner.com/vbb/showthread.php?t=181377
"G-Squares Are For Assholes"~PR_CB7
