Cant decide: TSX retrofit vs Lowering
    The retrofit isn't too difficult. Two of my friends have done it, and they both did a good job.
    I would stay away from Skunk2 suspension stuff, personally. That's more my own personal bias, though. I've had H&R forever, and I've always liked it. Neuspeed is pretty much the same thing.
    you would personally still do the retrofit first tho wouldnt you? and its not putting the projector in its the cutting part that would give me trouble plus all the projectors on ebay look like the dont come with brackets to hold it in place...
    MR : http://www.cb7tuner.com/vbb/showthre...ght=CB7+R3ason
    Originally posted by quaidum
    you being able to see four blocks down the road is resulting in someone not being able to see 5 feet in front of them
    good job, just what the world needs more inconsiderate drivers
      It depends on my needs.
      My H22 was my first mod, paint second, lowering 3rd, and HID projector retrofit fourth. I don't know which I would do first, honestly. The projectors are the cheapest, though... by far.
        you made your point i already have the paint i have a new f22a engine so im not swapping the engine anytime soon even tho a h23 or h22 would be nice i love my rims just bought a oem spoiler needs to be painted and mounted other than that it leaves the retrofit and lowering it and i will be a happy camper
          those MINI projectors you don't have to do any cutting am i right?
          Lou's Build Thread!
          http://www.cb7tuner.com/vbb/showthread.php?t=181377
          "G-Squares Are For Assholes"~PR_CB7
            if my memory serves me right you dont have tsx projectors you have a different projector thats not out of a honda or acura
              i think so but they are more expensive
                from what i hear the h1 version does not need any cutting to fit inside the bulb socket
                BUT the d2s version needs to have a bigger opening in the back of the housing to bring the projector through
                see how much bigger the silver ring is than the original bulb socket
                ''COUPE''
                ''WAGON''
                  well found another pair a headlights to do the retrofit project with at the local jy 50 bucks for both of them this way i dont mess up the ones on my car next thing is the projectors hopefully i can do this
                    retrofit!!! lowering is expensive
                    *shock
                    *springs
                    * camber kit (depending how low)
                    *new bushings (depensing how bad yours are)
                    *alignment (def will need it)
                    * new tires (lowering your car with bad tires is just as unsafe as lowering with cut springs)
                    I say retrofit.
                    Originally posted by Uncle Willey
                    When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
