looong trip..would my cb7 be able to make it???
    it's not the engine that id be worried about but smaller stuff like a starter. alternator, distributor, main relay.
    make sure the engine doesnt overheat as well.
    I <3 G60.
      in that case, if you need main relays i got a few, just let me know if you need them.
      CALI LIFE STYLE
      http://www.cb7tuner.com/vbb/showthread.php?t=145883
        i dont take my car on long trips, lol. i just take my family's community car (98 lexus es300) like when i went to stockton this weekend.
        my cb7 is just to goto school and work.
        I <3 G60.
          Check your heater hoses... If they haven't been replaced, then do it. The rubber gets old and deteriorates, cracks, leaks, no coolant, overheat.
          This winter I was doing about two and a half hours of driving everyday, and one of those hoses completely let go... I think it was just the extended heat. Other than that my car just did short trips.
          But yeah, check that out, and enjoy the trip. Loved taking my car on long drives
          RIP
          Bought from : LosiRacer2, h22anow
            i dont see why not
              all those are a year old. last year most of those parts were replaced. the ony one thing is bad now is the upper ball joint.
              Turbo F22 Under Construction
                I replace all the hoses while ago. i just need to replace one of the heater hoses.
                  I think i need a main relay my car is weird. when i try to start my car in the morning it wont start in the first crank but when i crank it again it starts right away.so i'm thinking main relay??
                  oh sorry i havent i didnt pick up the other day but i have hella shit going on with school. i'm taking to many classes.
                    check fuel pressure. mine..running sits at 29psi and i already done a fuel filter. it needs to turn over like 6 times for it to fire from a cold start. fuel pump soon
                    i have a fuel pressure kit and have set it up on a cb7 in about 5 minutes. lmk if you need help cause i know you are south bay.
                    I <3 G60.
                      Just Do The Maintanence And You'll Do Fine
                      VS
                      Mercyboy: I rather lose by a mile because I built my own car then win by an inch because someone else built it for me..your car is your story, so don't let someone else write the book!
                      MERCYBOY THREAD:http://www.cb7tuner.com/vbb/showthread.php?t=158241
                      1990 RHD Honda accord si CB3 Canada http://www.cb7tuner.com/vbb/showthread.php?t=196287
                      MY CB7 ON YOUTUBE: http://www.youtube.com/watch?v=CJID_IxwiNY
                        its cool bro, let me know when you get a chance to kick it. about the main relay just give me a call. if you need one i can give it to you, i work in san jose on story rd. so you can meet me there to pick it up.
                        CALI LIFE STYLE
                          so will changing my main relay fix the cold start problems?
                            it will fix a hot start problem.
                            I <3 G60.
                              thats probably your temp sensor.
                              JENNA 91 LX
                              RIP 12-11-09 - 12/06/10
                              JANE 99 Infiniti i30
                              2-9-11 - current
                              "Life is simple, you make choices and you don't look back."
                                well I guess my trip will be postponed, I was driving in an intersection and since the ground was wet i lost control and ran into a curve.
                                damage
                                -oil pan
                                -shocks
                                -probably coil overs
                                -driver side camber arm
                                -strut rod
                                -exhaust piping
                                -driver side axle
