Heat does not blow much..
    My heat/air that comes from under my driver and passenger seats blows a little bit but the air flow tht comes from there is minimal.. im not sayin that it should be as strong as the front vents but it is not that srong at all.
    Is this normal? What could my problem be?
    I don't believe it's supposed to be very strong. It's a rather small vent. Many cars don't even have that underseat vent... it's a farily interesting feature on the CB7.
      I just ripped mine out last week. All they are really for is warming your rear seat passengers' feet. I don't know how much air was supposed to blow out of them. The air inlet for those ducts is back behind the ash tray. You can access that area, with limited working space, by removing your center console. It's a huge pain to try and work around in there, but you could look and see if the damper is working properly, or if maybe something is blocking air flow.
        Thanks for the info. Im glad ithe underseat vent is there I just want it to work as it should.
          Thank You. I'll look into seeing if my air flow is being blocked and if not I may just have to remove the centre console.
