I have a friend of a friend that has the parts I want for my cb7. A4 header,A6 cam,ecu,tb/intake and black box. $50 WOOOOOO WHOOOOO!!! 125hp see yea!!!! 145-150HP here I come!!
sweet!!!
ok....
u have a Technical/Performance problem or something u wanna talk about? cuz thats whats this section if for.Project M3 - http://www.cb7tuner.com/vbb/showthread.php?t=157903
-(B-Pillar Bar Originator)-
You will be nowhere near 145-150 hp. If the motor was brand new and you put those parts on thats a different story. A new condition F22A1 was rated at 125 hp at the crank. Because of it being so old now, the stock F22A1 is probably around 100-110 hp at the crank. Depending on what condition your motor is in, you might see 125 hp at the crank AFTER you put those parts on.
Originally posted by visualpoet View PostYou realize that's crank hp, not whp, right? Factory (and new!) the a1 laid down about 110 at the wheels in the 5 speed.
Any questions regarding performance, maintenance, or repair belong here. If you want to go fast, or just change a flat... this is the place to ask!
I listed parts I got for my cb7 that increase the performance or make it go faster! According to the description of this forum Im in the right place.
Originally posted by AbsurdNY View PostYou will be nowhere near 145-150 hp. If the motor was brand new and you put those parts on thats a different story. A new condition F22A1 was rated at 125 hp at the crank. Because of it being so old now, the stock F22A1 is probably around 100-110 hp at the crank. Depending on what condition your motor is in, you might see 125 hp at the crank AFTER you put those parts on.
From what I seen the
F22A1 125hp/137tq
F22A4 130hp/142tq
F22A6 135hp/150tq or 140hp/155tq with A4 manifold!
5hp/5tq putting the A6 intake manifold on the A1 145hp/160tq
best case I will get 20whp/22wtq worst will be nothing. I will take it either way!!Last edited by cobra tom; 05-21-2009, 04:50 PM.
Originally posted by cobra tom View PostFrom what I seen the
F22A1 125hp/137tq
F22A4 130hp/142tq
F22A1 125hp/137tq
F22A4 130hp/142tq
If you start with the a1, your best bet is to go with all a6 parts and take that 15 hp difference, then get an SRI and a full exhaust. But every little bit helps.
i disagree, id use the A4 manifold. i could be wrong but i think the A4 is single walled, the A6 is dual walled. personal taste but id go A4, hey 1 or 2hp difference might be worth it, but 10lbs less in weight?
get a second iab plate and make a spacer and try and grab a H23 plenum and tb on the A6 runners. then u might see 140-145hp at the crank.
Originally posted by kc8enb07 View Posti disagree, id use the A4 manifold. i could be wrong but i think the A4 is single walled, the A6 is dual walled. personal taste but id go A4, hey 1 or 2hp difference might be worth it, but 10lbs less in weight?
i have a cheap 421, i have been thinking of going to an A4. quality seems better and u know there was some engineering in it.
just what id do
F22A1 - 125hp
add F22A6 intake and cam. so like 135hp
add the F22A4 exh. manifold, so MAYBE 142hp
then H23 tb and upper plenum w/ spacer, maybe 149hp
thats if u had a new engine. so u might see 140hp realistically
im going off the fact the 92-93 F22A6 is rated at 140hp/147tq
u have a Technical/Performance problem or something u wanna talk about? cuz thats whats this section if for.Originally posted by Flatline View Postokay.... do you have a technical/performance answer or comment?
"cuz thats whats this section if for"
hahah. OWNED!!!! (another off-topic)
