convincing HIM to let me do h22
    aiight do your best.
    what are the best reasons for doing an h22 swap beside the power increase.
    go go go go
      because its baller
      lets our accords haul more groceries
      newer engine = reliability (?)
        Tell him hes just gotta trust you and when its done he'll see.
        wat?
          As far as parts list:
          OBD1 Injectors.
          OBD1 ECU
          You don't need an OBD1 Dizzy. (I can post pics if that helps) You just need to make a harness for the Dizzy and crank pos. sensor.(I can explain if needed)
          You only need the esp mounts if you are auto.
          From looking at your sig, you will need to wire in the IABs as well.
          Obvious:
          V-TEC wiring
          Knock sensor (optional, ecu dependant)
          That's about it.
          Very easy swap in my book. Good luck with it.
          Black Housing DIY 1991 Wagon Morimoto Retrofit
          JDM One-Piece Headlight Lens Repair
            [QUOTE=djcaz_aom;1936549]As far as parts list:
            yo man can u explain that and yes i am auto.
              "dadd, the engine's newer. It'll last longer".
              Worked with my mom when I told her I wanted to do an H swap. She said it was stupid, then after that, I got an "ehhh, whatever you wanna do".
              98' Mustang 3V Swap
              11' VW CC R36
                If the 454 motor in his Chevy was not original to the car, then tell him "I'm doing it for the same reason your 454 is in your Chevy".
                  [QUOTE=91project;1936649]
                  I am running the OBD2 dizzy on my H22A4. The big difference is that the crank pos sensor is down by the crank pulley.
                  I cut the pigtail from the harness for sensor (the one that plugs into the sensor) and extended two wires up to the dizzy.
                  I got both pigtails from an OBD1 dizzy (male and female) and made an adapter using the 2 wires from the CPS.
                  Here is a rough sketch:
                  Hope that helps.
                    yes it does...thanks man
                      No problem. If you need any more info, just ask. Good luck with the swap.
                        LoL sound like my mom
                          Your dad owns a junkyard?
                          That must be sick.
                          Originally posted by chessboxer
                          We know these are good cars, but for some reason, all the world wants are freaking civics and tegs. Bleck.
                          Bought From: Slammed4thGen TypeG x2DeevergoteBillKisme
                            man this was like 4 months ago what happened did you swap??
                            Ride List
                            1990 Accord dx coupe - my baby (dsm turbo set up in progress) http://www.cardomain.com/ride/3202853
                            2005 Mazda 6s - daily driver http://www.cardomain.com/ride/3171724(totaled)
                            newest 2006 mazdaspeed 6 http://www.cardomain.com/ride/4073987/2006-mazda-mazda6
