jdm ascot front clip
    Originally posted by blizzard335 View Post
    it will.
    the Ascot IS a CB, btw.
    all you need are the fenders and stuff.
    from the pics i found i need the fenders,hood,grille,headlites and bumper.
    now to find a japan connection
      Hi
      That my car in the video
      There is the front clip, I bot it in Montreal, Canada three years ago
      You can keep your fender, but you will need to relocate the corner hole to make it fit
      the rad support is ¼ inch higger, so you need to do some body work
      you also need to cut the hood to make place for the grill
      H23a VTEC Supercharged
      13.997 @ 101 MPH, enfin!!!
        Originally posted by quickaccord93 View Post
        Hi
        wow..... how much HP you get with that supercharge?
        Links to my rides :
        1992 Accord EX*
        1990 Accord EX
        1991 Accord SE (4th)
        1991 Accord SE (3rd)
        1991 Accord SE (2ND)
        1991 Accord SE
          and for the h23a Vtec
          The engine come from a 6th gen accord wagon in japan
          I think frame code CF9, not sure. I got the engine from a JDM importer in Montreal, and there are many more for salehttp://www.enginelandinc.com/show.as...categorykey=81
          Sorry for the french writing, but you will understand
          Nom: H23A
          Voiture d'origine: Accord Wagon 98-02
          Marché: Japonais (JDM)
          Configuration: DOHC 16 valves
          Alimentation: PGM-FI
          Type: VTEC
          Ratio de compression: 10.6:1
          Alésage x course: 87mm x 95mm
          Déplacement: 2258cc
          Puissance: 200cv à 6800 tours
          Couple: 163lbs-pieds à 5300 tours
            225 hp @ 5000 rpm, That's was 3 years ago, i did not have time to retune my setup. After 5000 rpm, the curve drop from 225 to 150 Hp. My exaust is too small (OEM cat)
            My accord sit in the garage, I got two kids, so not more time and money on the car
              I hear that. I have 1 kid my self and I know how hard it can be. When you do get her out again you should take a Video (again) with you pushing it
              were are you located?
              Links to my rides :
              1992 Accord EX*
              1990 Accord EX
              1991 Accord SE
                Montréal, Québec
                I'm the founder of the Quebec Accord Club.
                If you have time, got to www.clubaccordquebec.com/forum
                  gain of 25hp? good enough
                  how much torque did you get?
                  yes, the H23a VTEC came from either the CH9 or CL2 (AWD)
                  Click sig to view MR thread
                  Links to other rides:
                  Honda Accord Euro-R
                  Honda Odyssey Absolute
                  Honda City I-DSi
                  Honda Stream
                    Montréal, Québec
                    you should make an MR about your car sir
                    get those 29 more posts!
                    Honda Accord Euro-R
                    Honda City I-DSi
                    Honda Stream
                      at the wheel
                      with only the h23a, i got 178 WHP
                        at the wheel
                        225whp? awesome
                        the H23a VTEC puts down 178whp??? OMFG!
                        Honda Accord Euro-R
                        Honda City I-DSi
                        Honda Stream
                          Why replace the CB7 front end >< it looks so much better ><
                            daaaam! 178hp stock that's whatsup. an h22 is only like 150hp stock right?
                              The h22 pushes 200 at the crank but around 162 to the wheels
                              My Memebers ride thread is comin soon keep out on the look out.
                                I wonder how a supercharge + turbo would be on a h's?
