Anyone herd of this turbo I just picked it up for trade, I traded my xbox 360 and some other stuff if you know what this turbo is capable let me know thanks.
IHI Turbo
IHI also makes subaru turbos, but i doubt you have that one, the exhaust inlet is a wierd design and would require an adapter plate for it to work. also the exhaust outlet is a 5 bolt, but not the typical 5 bolt, also would require a custom flange made.
Hola, tengo tres patas. Me llamo tripod.
Originally posted by d112crzySo you're throwing a bitch fit because some other girl at school has the same nail polish and skirt as you do?
shit, i would have gave you a turbo you could actually use for an Xbox 360
Originally posted by Accord R33 View Postshit, i would gave gave you a turbo you could actually use for an Xbox 360
i only know the flanges on the IHI turbos for Subies, but i dont know about the other flanges. not sure if they are the typical t3/t4 or whatnot. but yeh if its a subie IHI then have fun finding flanges/adapters for the d/p and the manifold.
**EDIT - found some flanges for the Subies, but it would still all be custom work. good luck to ya.
the turbo you posted is def a subie turbo prob a vf34 found on jdm sti's i believe. dont quote me on that. its going to be more stress to get the flanges to work for you. DSM turbos are cheaper, you can even go with the evo8/9 setups. and with that you wont have to worry about fitment issues. up to you, the hardest flange to modify to get that turbo to work is the uppipe flange which is the exhaust inlet.
if it is the vf34 it does retail around 1000, but you wont get that for it. you will be lucky to get 600, so if you think its worth the trade then go for it. you have to see the turbo itself, and on the rectangular piece of the compressor housing it will say which turbo it is. ihi's VF series is rather big, so just look into it. there is the vf22, 34, 39, and 43 that i know off hand right now.
