how does 2" drop look like?
    Originally posted by CB7_AUST
    Hi..
    Just wondering if someone can explain to me... why a car sits higher off the ground when its running 17/18" rims compared to the stock 15". When theoretically, the diameter and circumference of both the 15"+tire is the same as 17"+tire?
    15" is smaller and with smaller tires
    17" is bigger and with bigger tires
    Originally posted by jhondayaaj
    too bad seattle silver's are the best.
    ACCORD MEET MAY 29th 2010
      Sorry but that doesnt really tell me anything...
      Let me give you an example.
      195/60/15 has circumference of 76.1 inches
      205/45/17 has circumference of 76.2 inches
      Although they are almost identical circle sizes... a 17" on the accord looks like its much higher then stock height..
        there you go, you answer it
          Both Accords in my sig have Skunk2 lowering springs that are 2.25".
          The 94 has stock shocks (that are blown) and the 92 has Skunk2 struts.
            i dont know how to describe it in technical words.
            imagine you had 2 5 spoke rims right? 1 is 17 and 1 is 15...if you look at the spokes the 17 will have longer spokes on it.
            now imagine where the hub is connected to the rims the middle where you put the lugs in..from that middle to the outer circle or the edge of the lip ( barrel of the rim) that part the 17 will be longer compared to a 15...thats what makes it taller the inner diameter from the hub to the outer circle which actually makes the car higher..not the whole diameter of of the tires.
            kinda lame how i explained it but should be easy enough to understand.
            "as i ride the twisties of death,i shall fear no corner"
            change da game...bosozoku honda's for the muthafuccin win!
            www.tougesports.com
              Soo... its like your comparing the radius of the two wheels? but like i said... doesnt the tires compensate for the radius difference between the two wheels? =S
                There are a few factors involved, but what you're saying is right the diameter of both will be close enough, but when comparing the 2 the difference is the measurement from the axle nut to the ground and the stiffness of the sidewall on the tires. When comparing a 15" and 17" wheel, the measurement from the axle nut to the fender edge should be the same since that is how drops are measured.
                If you put 17's on stock suspension the whole body lifts up, but if you measure the axle nut to the fender it'll be the same as the 15" wheel.
                  skunk2s usually go a lil over 2.5
                    just put on whatever looks good.........end of story..
                      they look good....
                        do you have to get an alignment or camber if you drop 2"?
                          hi i am new to tha forum. i have a 90 cb7 and was wondering what would be the best way to drop my car, coilovers or lowering springs? thanks in advance for any help
                            well that all has to do with how much money you are willing to spend and what you want.
                            Coilovers are more expensive but most you can adjust height and stiffness. With springs they are cheaper and can still give you a nice ride. Just make sure you get some decent struts aswell.
                            Three keys
                            Stay away from ebay suspension
                            Camber kit if you go really low
                            get struts
                            Im on tein s tech springs with gr2 struts very nice
                              if you want a better ride...yes...
                                get some more pics up guys, i want to see more pics of 2" drop
                                member ride thread
                                MN ACCORD MEET MAY 29th 2010
