F20A CB7 : 1990 Accord LX
    Changed the acorn style nuts/bolts to wing nuts... i did so because im always breaking, stripping or busting the nut in half (lol i said bustin a nut) here are some pics.
      I broke one of those off myself when putting your vc on! I'm reeeal careful now!
      MRT
      14.38 @ 98.66mph
      Current fastest Laguna Seca Lap: 1:52.346
        I don't have 2 b so careful now thanks to the wing nuts.
          Did my 1st timing belt job today with Joe Vasquez thanks a lot pal... had master chief Jose Ortiz come by to check the tension.. at 1st the belt didn't want to get tight... all it was a dam spring was on backwards..
          Look at the oem balance shaft belt. Split in 2 when the cover came off... look at the threads showing on the tb.. jeepers creepers!
          F20A made in 92.. never changed anything inside the lower timing cover..
          I did, cam seal, crank seal, balance shaft seal with recall tool which holds the seal back from oil pushing it forward.. timing belt and balance belt..
            Ppl can't funkin park!
            Now I need a bumper..
              Sorry man, you've had some bad luck recently. All will turn around soon.
              MRT
              14.38 @ 98.66mph
                That sucks bro , but hey i just replaced my driver fender on Monday that was dented from the previous owner and on Friday i side swiped a civic in rush hour. yay. some how i didn't bust my new corner light.
                CB7TUNER.com
                Educating each other one car at a time.
                  Vandel:
                  Car broken into 2 times in the past 8 months. Radio removed, steering wheel from coupe days cuz in half.
                  Paint was sprayed back to front in blk wavey design on passenger side
                  Rear bumper paint removed
                  Driver side fender pushed in from some1 hittin it to the point I couldn't even open my door
                  Passenger side fender side swipped a park car.. after xgf told me sshe didn't love me anymore and ran off with a hillbilly who the got caught by the fbi's.
                  Rock thrown from park. Landed on windshield, now its spreading cuz the weather.
                  Yep far shares of bs BY PPL. BUT HEY. I STAND BACK. AND SAY.. I LOVE MY CB7TUNER. MY CMMUNITY ADMIRES MY CAR AND PROJECTS.. I NEED 2 KEEP GOING.
                  I'M HERE1
                    sorry to here about this man and i hope it turns around really soon .
                    this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
                    Car safety checks
                    Fluid Capacities
                      Glad you got your timing belt sorted out, with the weather changing, theyre notorious for just snapping upon startup when its cold and theyre worn (belts in general)
                      This is the CD5s I started it up and it was maybe 20 degrees, Pulled out go maybe 100 feet from the house and KERPLUNK.
                      from now on if I buy another honda, timing service will the first thing done..Im just glad it broke down where I could push it back home with the CB
                        Damn dude.. I bought NGK wires plugs OEM oil filter o ring cap and rotor vc gasget tube seals drain bolt all for 125... Great price... Advance cap and rotor..NGK wires is 95 plus all the extra shit was worth it.
                          Cb dealer option wheels 14x5.5 +55 offset, clean, I think so.
                            Clean!!!! Love originality!!! I coulda sworn you had black housing headlights on there..
                              The lense on the inside is blk housed. The top, bottom and sides.
                                Josh, how's everything going with you these days? Happy Thanksgiving!
                                MRT
                                14.38 @ 98.66mph
