The body kit robs the car of its beautiful lines. Still a nice car. I have had hardly any sleep the past day but........ how come I see no IC. Or am I tripping?
H22 Turbo n00b
I fly by like the coupe grew wings!!!
Speeding!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
My coupe!!!
http://www.cb7tuner.com/vbb/showthread.php?t=152924
Originally posted by Racer_XXXExcuse me miss, YOUR FUPA IS IN THE WAY!!!
Originally posted by daheavyking View PostThe body kit robs the car of its beautiful lines. Still a nice car. I have had hardly any sleep the past day but........ how come I see no IC. Or am I tripping?
Idk I thought some turbo set ups didnt need intercoolers, idk if you have ever heard of "sleeper" turbos, they are like exshaust turbos..... And yeah im going oem front with lip for sure, body kits are flimsy and too ricey...lol
A turbo setup should ALWAYS have an intercooler... some cars came without from the factory, but when boosting an engine that wasn't made for it, it's a necessity. Turbos make a LOT of heat, and heat kills engines. The intercooler is there to help take some of that heat away before it does damage.
I don't see how that could be intercooled... looks like the pipe is running straight to the throttle body.
The H22 has fairly high compression, and "weak" internals (not really weak, but they don't hold up to boost for very long, as they aren't made for it...) Even with everything done properly, a stock-block H22 will often blow up. I'm amazed this car made it from AZ to CA without grenading!
Definitely dig into that car (and don't drive it... unless you want to replace the engine soon...) Share what you find, and we'll help you put things together as it SHOULD be!
I wish it was possible to reliably turbo a car with no intercooler... that makes things so much more simple!
You might run into a lot of problems with that turbo charged car. Your in California still or are you in Arizona because if your in Arizona your fine but if your in California you will run into smog issues and will not pass the visual inspection. That is unless you know someone . I like what you have going for the car an I hope all goes well from here on. Just looking out for a fellow cb7 tuner member .
Rip It Up
Sold to: nightime25, MyDianaz06, Accord214 and 408cb7
Bought from:Rob_is_Legend, MonoCB7, Fatboy1185, Flatline and busak87
i vouch for my Brothas
Originally posted by SNOOZE View PostHaha for real, why would I lie about having a turbo.... Im not trying to impress no one, I need help with this carmore like it! I dont even know how to use photoshop..lol
But upon a closer look I can see the whole thing.Originally posted by chessboxerWe know these are good cars, but for some reason, all the world wants are freaking civics and tegs. Bleck.
Originally posted by nevi325 View Postlove that 3rd pic
Originally posted by deevergote View PostA turbo setup should ALWAYS have an intercooler... some cars came without from the factory, but when boosting an engine that wasn't made for it, it's a necessity. Turbos make a LOT of heat, and heat kills engines. The intercooler is there to help take some of that heat away before it does damage.
Originally posted by Extacee View PostYou might run into a lot of problems with that turbo charged car. Your in California still or are you in Arizona because if your in Arizona your fine but if your in California you will run into smog issues and will not pass the visual inspection. That is unless you know someone . I like what you have going for the car an I hope all goes well from here on. Just looking out for a fellow cb7 tuner member .
Originally posted by deevergote View PostSmart man.
I think you taking ownership of this car may be what saves its life!
